Standard Magnification is the magnification determined by the publisher of the documents--that is, the default. You can set other magnification values by choosing Custom Magnification. This opens the Custom Magnification window.
Drag the slider to the desired value.
Press SELECT on the slider control as you move it. The amount of magnification is specified in the Magnification Percentage field.
Click SELECT on Apply.
This puts the new page magnification into effect.
Clicking SELECT on Reset reverts to the previous setting. Single clicks on the left or right of the slider cause one-percent increments up or down the scale.
