OpenWindows User's Guide
Updating and Viewing System and Network Binder Entries
If you want to modify your system bindings, you must become root and start Binder by typing binder -system in a Shell Tool or Command Tool.
In order to modify the network bindings, you need to have root access on your OpenWindows server workstation, and you need to start Binder by typing binder -network in a Shell Tool or Command Tool.
If you cannot start the Binder as root, you probably need to restart OpenWindows with the noauth option. To do this, exit the window system and type openwin -noauth at the console.
The entries on the View menu have a different meaning if you are running the Binder with the command-line options listed previously.
If you run the Binder with the -system option, all new entries are added to your system database. In this case you use the View menu as follows:
If you run the Binder with the -network option, all new entries are added to the network database. In this case the View menu is dimmed and unavailable. Only the network entries are displayed.
To modify entries for local use on your machine, you need to copy them from the system and network databases into your private database. To copy an entry to your database, first scroll through the list of Binder entries in the Binder base window until you see the one you want to modify.
  1. Click SELECT on the Binder entry you want to modify.
    A rectangle appears around the chosen entry. The example in Figure 16-2 is the icon for the Mail Tool application.
    Figure 16-2 Choosing the Mail Tool Icon Entry
    Graphic
  2. Click SELECT on the Duplicate button.
    The entry is copied into your private database.
  3. Choose View -> Personal Entries.
    The view changes to your personal database, listing the newly copied entry and any others that you may have. The copied entry has the temporary name unnamed_1.
    Figure 16-3 shows a private Binder database with the newly copied entry.
    Figure 16-3 Private Binder Database
    Graphic
    Note -
    If you run Binder as root without the -system or -network command-line options listed above, you will only be able to modify the personal Binder entries for user "root." Make sure to use the command-line options if you want to modify the system or network entries.
