Finding a Specific Calendar Date
Sometimes you may need to look at or "go to" a specific date very quickly. Instead of using the navigator buttons to do this, you can use the Go To function.
Choose View-> GoTo.
You see the Go To Date window.
Type the exact date on the Date: line, and SELECT the GoTo button.
The date must be in the format specified in the Date Format Properties. Depending on the view selected, the day is shown or highlighted.
