The following keyboard accelerators require that you use mouseless mode. You can set this from the Properties menu:
Sequence |
Action |
Alt-w |
Moves focus to the next window within the current application |
Shift-Alt-w |
Moves focus to the previous window within the current application |
Alt-n |
Moves focus to the next application |
Shift-Alt-n |
Moves focus to the previous application |
Shift-Alt-m |
Displays Workspace menu |
Sequence |
Action |
Alt-m |
Displays window menu |
Alt-F5 |
Moves window to back |
Alt-F6 |
Enables you to move window with arrow keys |
Alt-F7 |
Enables you to resize window with arrow keys |
Alt-F8 |
Refreshes window |
Table 17-6 Commands that Manipulate Base Windows Only
Sequence |
Action |
Alt-F2 |
Opens the icon at the pointer location or closes the window at the pointer location |
Alt-F3 |
Resizes window to full size or reduces it to default size |
Alt-F9 |
Quits application |
Table 17-7 Commands that Manipulate Pop-Up Window Menus
Sequence |
Action |
Alt-F2 |
Dismisses or cancels pop-up menu |
Alt-F10 |
Indicates owner of pop-up menu |
