Use the Print window, shown in Figure 15-15, to print icon files. This window displays when you choose Print from the File menu.
You can specify the following options from the Icon Editor Print window:
Destination of the printed output (Printer or File)
Printer name and printer options, or file destination and file name
If the Destination is Printer, as in Figure 15-15, a field called Options is displayed. You can type in UNIX commands in this field to customize your printer option defaults.
Width and height of the printed image
Left and bottom margins of the printed image
Number of copies to print
When you've chosen your Printer Settings, click SELECT on the Print button to print the icon.
