To save a file or document as one of the available formats:
Choose File -> Save As.
Type a new name and extension for the file, if necessary.
Select a new file format.
Image Tool can save files in the following formats:
PostScript
EPSF
GIF
JFIF (JPEG)
Sun Raster
TIFF
Select a Compression method, if applicable.
The following compression methods are available:
None
UNIX --Standard UNIX file compression utility, available for (ESPF), PostScript, Sun Raster, and TIFF formats
Encoded run length--Available for Sun Raster
LZW--Available for TIFF files
JPEG--Available for JFIF files
Available compression methods depend upon selected format. Compression saves disk space.
Select a color attribute, if applicable.
Available color attributes are: Black and White, 256, Millions.
Select Save.
