OpenWindows User's Guide
Printing Your Documents
To print documents, you use Print Tool. Print Tool enables you to print documents from a variety of formats, including ASCII, troff, PostScript text, and raster images. Figure 1-32 shows the Print Tool application window.
Figure 1-32 The Print Tool Application Window
Graphic
To print a document, you can drag a file icon from File Manager and drop it on the Print Tool icon or on the open Print Tool drag and drop target. Another method is to type the file and pathname in the Print Tool text field and click SELECT on the Print button. You can also send messages and images to the printer from Multimedia Mail Tool and from Snapshot--an application that enables you to take pictures of windows and images on your workstation screen.
