You can use Print Tool to print your mail messages using these steps:
With both Mail Tool and Print Tool running, select the headers for the messages you want to print.
Press SELECT and drag the headers until the hot spot of the pointer is on the Print Tool drag and drop target.
The drag and drop target is the box in the upper left corner of the Print Tool window.
The pointer changes to a document glyph if you are dragging one mail header to indicate that what is being dragged is document. The pointer changes to three document glyphs if you are dragging several mail headers. In the example shown in Figure 4-11, two files have been selected for printing.
Release SELECT to drop the headers.
Messages are displayed in the footer of the Print Tool window displaying the printing status.
If a selected mail message has attachments, and the message is dropped on the Print Tool, the attachments are not printed. A message is printed that tells how many attachments are with the message. To print an attachment, open the attachment and print it using the attachment's application, or drag just the attachment to the Print Tool.
