Checking the Tape Contents
Before deleting the backup files from your system, make certain that the copy occurred. At any time, you can list the files on a tape as follows:
Insert the tape into the tape drive.
Click SELECT on the List button in the Tape Tool base window.
In a few moments, the contents of the tape are listed in the Tape Contents window pane. Messages in the footer tell you how many files have been found.
