Before you press the Calibrate... button, you must choose a monitor.
Click on Monitors.
A list of monitor profiles available in your environment is displayed as shown in Figure 10-1.
Select a Monitor Type.
If you do not know the type of monitor you have, you can get general information about a monitor by clicking on the More... button. The information is displayed in a separate window. The following information is an example of the type of information given when you select a Sony 16" profile and press the More... button:
Color space = RGB
Device manufacturer = Sony
Device model = 16"
White point = 0.964294 1.000000 0.825104, press OK to dismiss window
You can also use Table 10-2 to help you choose a monitor. The Sun part number is located on the monitor's nameplate. Find the part number on your monitor and match it to the part number in this table. Use the rest of the information in the row to choose a monitor.
Sun Part Number |
Description |
Manufacturer |
Profile Description |
365-1130-01 |
P3 16" Color |
Sony |
Sony 13/16/19" Monitor |
365-1112-01 |
P3 19" Color |
Sony |
365-1159-01 |
P3 16" Color |
Sony |
365-1160-01 |
P3 19" Color |
Sony |
365-1147-01 |
P3 16" Color SH (Southern Hemisphere) |
Sony |
365-1148-01 |
P3 19" Color SH |
Sony |
365-1288-01 |
P3 19" Color Logoless |
Sony |
365-1289-01 |
P3 16" Color Logoless |
Sony |
Sony 13, 16 and 19" Monitor |
365-1153-01 |
Skol 19" P3 MPR2 |
Sony |
N/A |
365-1151-02 |
Rosebud 17" Mid Range (MR) Color |
Sony |
N/A |
365-1166-02 |
Rosebud 17" MR Color Logoless |
Sony |
N/A |
365-1164-02 |
Rosebud 17" MR SH Color |
Sony |
N/A |
365-1165-02 |
Rosebud 17" MPR2 MR |
Sony |
N/A |
365-1068-01 |
21" Color |
Toshiba |
N/A |
365-1286-01 |
Tulip 15" FS Color |
Nokia |
Sony 15" Monitor |
365-1167-01 |
Corona P4 20" Color |
Sony |
Sony 20" Monitor |
365-1313-01 |
Corona P4 20" Color Logoless |
Sony |
Sony 20" Monitor |
365-1317-01 |
Corona P4 20" Color SH |
Sony |
Sony 20" Monitor |
365-1316-01 |
Jasmine 17" N1 Color |
Sony |
