The basic form of the ex copy command is:
| :line#,line# co line# |
The first two numbers (separated by a comma) specify the range of lines to be copied. The third number is the line before the insertion point.
For example, to copy lines 1 through 5 of paint and place the copy after line 12, you would type the following:
| :1,5 co 12 |
and press Return.
When specifying line ranges, use the abbreviations
Thus, to copy the range "from the current line through line 5" and insert this block after line 12, you would type:
| :.,5 co 12 |
To copy the range "from line 6 through the end of the file" and insert this block after line 2, you would type:
| :6,$ co 2 |
