OpenWindows Advanced User's Guide
6.6.3 Moving Lines
The basic form of the ex move command is similar to the copy command discussed above:
:line#,line# m line#
Line ranges and insertion points are specified in the same ways, including use of the abbreviations . and $. The difference in function is simply that "move" removes a block from one location and reinserts it elsewhere.
For example, to move lines 1 through 5 to the line following 12, you would type:
:1,5 m 12
and press Return.
