If you have already formatted your PCMCIA memory card, skip this section.
Insert the PCMCIA memory card in the PCMCIA socket.
Enter a command to format the memory card with the desired file system (UNIX or MS-DOS).
The format utility cannot be used with PCMCIA memory cards. Only the fdformat utility will work.
To format a memory card with a UNIX file system, type the following commands:
% fdformat device_name % newfs device_name |
For example, to format a PCMCIA memory card in a disk drive with an assigned device name of /dev/dsk/c1t6d0s2, type:
% fdformat /dev/dsk/c1t6d0s2 % newfs /dev/dsk/c1t6d0s2 |
To format a memory card with an MS-DOS file system, type one of the following commands:
% fdformat -d device_name |
or
% fdformat -t dos device_name |
% fdformat -d /dev/dsk/c1t6d0s2 |
or
% fdformat -t dos /dev/dsk/c1t6d0s2 |
Removing a PCMCIA memory card while mounted results in a system panic.
