Mount a PCMCIA memory card with a UNIX file system by typing:
# mount mount_directory device_name |
If there is no /mnt directory, type:
example# mkdir /mnt |
For example, to mount a UNIX file system in the /mnt directory on a disk drive with an assigned address of c1t6d0s2, type:
example# mount /dev/dsk/c1t6d0s2 /mnt |
Mount a PCMCIA memory card with a MS-DOS file system by typing:
# mount -F pcfs mount_directory device_name |
If there is no /pcfs directory, type:
example# mkdir /pcfs |
For example, to mount an MS-DOS file system in the /pcfs directory on a disk drive with an assigned address of c1t6d0s2, type:
example# mount -F pcfs /dev/dsk/c1t6d0s2 /pcfs |
