Solaris Common Desktop Environment: Programmer's Guide
Entry attributes for recurrence information
For data versions 1 to 3, the following entry attributes are used to specify recurrence information for an entry. They are all read/write attributes.
CSA_X_DT_ENTRY_ATTR_REPEAT_TYPE
CSA_X_DT_ENTRY_ATTR_REPEAT_TIMES
CSA_X_DT_ENTRY_ATTR_REPEAT_INTERVAL
CSA_X_DT_ENTRY_ATTR_REPEAT_OCCURRENCE_NUM
CSA_X_DT_ENTRY_ATTR_SEQUENCE_END_DATE
For data version 4, entry attributes CSA_ENTRY_ATTR_RECURRENCE_RULE and CSA_ENTRY_ATTR_EXCEPTION_DATES are used to specify recurrence information of a calendar entry. Information in the CSA_ENTRY_ATTR_RECURRENCE_RULE attribute can be queried using the following attributes:
These computed attributes are read-only for data version 4.
