CSA_ENTRY_ATTR_STATUS
This attribute is not supported in data version 1.
Data versions 2 and 3 support the following values:
CSA_X_DT_STATUS_ACTIVE CSA_X_DT_STATUS_DELETE_PENDING CSA_X_DT_STATUS_ADD_PENDING CSA_X_DT_STATUS_COMMITTED CSA_X_DT_STATUS_CANCELLED
Data version 4 supports all status values:
CSA_STATUS_ACCEPTED CSA_STATUS_NEEDS_ACTION CSA_STATUS_SENT CSA_STATUS_TENTATIVE CSA_STATUS_CONFIRMED CSA_STATUS_REJECTED CSA_STATUS_COMPLETED CSA_STATUS_DELEGATED CSA_X_DT_STATUS_ACTIVE CSA_X_DT_STATUS_DELETE_PENDING CSA_X_DT_STATUS_ADD_PENDING CSA_X_DT_STATUS_COMMITTED CSA_X_DT_STATUS_CANCELLED
CSA_ENTRY_ATTR_SUBTYPE
Data versions 1 to 3 support the following values:
CSA_SUBTYPE_APPOINTMENT CSA_SUBTYPE_HOLIDAY
Data version 4 supports all defined values as well as the following application-defined values:
CSA_SUBTYPE_APPOINTMENT CSA_SUBTYPE_CLASS CSA_SUBTYPE_HOLIDAY CSA_SUBTYPE_MEETING CSA_SUBTYPE_MISCELLANEOUS CSA_SUBTYPE_PHONE_CALL CSA_SUBTYPE_SICK_DAY CSA_SUBTYPE_SPECIAL_OCCASION CSA_SUBTYPE_TRAVEL CSA_SUBTYPE_VACATION
CSA_ENTRY_ATTR_TYPE
CSA_TYPE_EVENT CSA_TYPE_TODO CSA_X_DT_TYPE_OTHER
Data version 4 supports all defined values:
CSA_TYPE_EVENT CSA_TYPE_TODO CSA_TYPE_MEMO CSA_X_DT_TYPE_OTHER
Only some combinations of type and subtype values--listed below--are supported in data version 1 to 3.
Combinations supported in data version 1:
CSA_TYPE_EVENT with subtype CSA_SUBTYPE_APPOINTMENT CSA_X_DT_TYPE_OTHER with no subtype value
Combinations supported in data versions 2 and 3:
CSA_TYPE_EVENT with subtype CSA_SUBTYPE_APPOINTMENT CSA_TYPE_EVENT with subtype CSA_SUBTYPE_HOLIDAY CSA_TYPE_TODO with no subtype value CSA_X_DT_TYPE_OTHER with no subtype value
CSA_X_ENTRY_ATTR_REPEAT_TYPE
For data versions 1 to 3, this attribute is used to specify the type of recurrence of an entry.
Values supported in data versions 1 and 2:
CSA_X_DT_REPEAT_ONETIME CSA_X_DT_REPEAT_DAILY CSA_X_DT_REPEAT_WEEKLY CSA_X_DT_REPEAT_BIWEEKLY CSA_X_DT_REPEAT_MONTHLY_BY_DATE CSA_X_DT_REPEAT_YEARLY
Values supported in data version 3:
CSA_X_DT_REPEAT_ONETIME CSA_X_DT_REPEAT_DAILY CSA_X_DT_REPEAT_WEEKLY CSA_X_DT_REPEAT_BIWEEKLY CSA_X_DT_REPEAT_MONTHLY_BY_WEEKDAY CSA_X_DT_REPEAT_MONTHLY_BY_DATE CSA_X_DT_REPEAT_YEARLY CSA_X_DT_REPEAT_EVERY_NDAY CSA_X_DT_REPEAT_EVERY_NWEEK CSA_X_DT_REPEAT_EVERY_NMONTH CSA_X_DT_REPEAT_MON_TO_FRI CSA_X_DT_REPEAT_MONWEDFRI CSA_X_DT_REPEAT_TUETHUR CSA_X_DT_REPEAT_WEEKDAYCOMBO CSA_X_DT_REPEAT_OTHER
For data version 4, this is a read-only attribute and the value is derived from the entry attribute CSA_ENTRY_ATTR_RECURRENCE_RULE.
