Solaris Common Desktop Environment: Motif Transition Guide
Solaris CDE Libraries for Motif
Motif Library (libXm)
Solaris CDE provides all the Motif 1.2.5 header files. The Solaris CDE libraries for Motif are the Motif 1.2.5 libraries with bug fixes and enhancements.
Motif UIL library (libUill)
The Motif user interface language (UIL) is a specification language for describing the initial state of a Motif application's user interface. The CDE version of the Motif UIL library is essentially unchanged from the Motif 1.2.5 version.
Include the UilDef.h header file (found in the /usr/dt/include/uil directory) to access UIL.
Motif Resource Manager Library (libMrm)
The Motif resource manager (MRM) is responsible for creating widgets based on definitions contained in user interface definition (UID) files created by the UIL compiler. MRM interprets the output of the UIL compiler and generates the appropriate argument lists for widget creation functions. Use libMrm to access the Motif resource manager. The CDE version is essentially unchanged from the Motif version.
Include the Mrm/MrmPublic.h header files to access libMrm in your application.
