Solaris Common Desktop Environment: Motif Transition Guide
Programming Model
Although the APIs are different, both XView and Motif are based on the same object-oriented methodology for programming a user interface:
The overall structure of a program being ported from XView to Motif can remain intact even though all the function calls must be converted from one API to the other.
Common Types of User Interface Objects
Both XView and Motif are user interface toolkits that support some common types of user interface objects. However, XView implements many of these objects at a higher level that requires more than one Motif widget to produce the equivalent of a single XView object.
Table 5-3 lists the basic mapping of common objects for XView and its equivalent Solaris Motif widget:
Table 5-3 Basic Mapping of Common Objects.
XView Package
Equivalent Solaris Motif Widget
Base Frame
XmTopLevelShell + XmMainWindow
Command Frame
XmDialogShell + XmBulletinBoard
Notice
XmDialogShell + XmMessageBox (MessageDialog)
Canvas
XmScrolledWindow + XmDrawingArea
Panel
XmBulletinBoard or XmForm
Panel Button
XmPushButton
Menu Button
DtMenuButton (not accessible in OpenWindows environment)
Abbrev Menu Button
XmRowColumn (Option Menu)
Checkbox
XmRowColumn + XmToggleButtons (CheckBox)
Exclusive Choice
XmRowColumn + XmToggleButtons (Radio Box)
Scrolling List
XmScrolledWindow + XmList
Message
XmLabel
Slider
XmScale
Text Field
XmTextField
Numeric Text Field
DtSpinBox (not accessible in OpenWindows environment)
Text SubWindow
XmScrolledWindow + XmText (ScrolledText)
TTY SubWindow
XmScrolledWindow + XmTermPane;
DtTerm (not accessible in OpenWindows environment)
Scrollbar
XmScrollBar
Popup Menu
XmMenuShell + XmRowColumn (Popup Menu)
Pulldown Menu
XmMenuShell + XmRowColumn (Pulldown Menu)
Pullright Menu
File Chooser
XmDialogShell + XmFileSelectionBox
