Solaris Common Desktop Environment: Motif Transition Guide
Notable Implementation Differences Between Toolkits
Many features are roughly equivalent in the OPEN LOOK user interface and Solaris Motif but have significant implementation differences. The following are the most important differences:
Other significant differences include the following:
The remainder of this section provides information on some of these features.
Tear-off Menus
In Solaris Motif, tear-off menus replace the pinned menus of the OPEN LOOK user interface. Selecting the dashed line on the top of the menu "tears-off" the menu.
Secondary Text Selection
The OPEN LOOK secondary text selection is roughly analogous to the Motif quick transfer mechanism.
Window Controls
One of the most critical implementation differences involves window controls. When the Motif user presses the Window menu button in the upper left corner of the title bar, or the OPEN LOOK user presses the MENU button anywhere on the window background (including the header), a menu is displayed. The options offered under the two GUIs introduce a key contrast.
The Motif Window menu offers a choice of Restore, Move, Size, Minimize, Maximize, Lower, and Close. The OPEN LOOK base Window menu offers Close, Full Size, Properties, Back, Refresh, and Quit. The two lists are fundamentally the same, but have very different effects.
In the OPEN LOOK user interface, the Close option minimizes (iconifies) the window, and Quit terminates the application.
In Motif, the Minimize option minimizes the window, and the Close option terminates the application. Many users familiar with the OPEN LOOK user interface have found themselves exiting a Motif program when their intent was to close its window to an icon.
Mouse Button Behavior
The structure of the mouse buttons is very similar in both specifications; however, the difference is significant enough to cause some confusion.
Table 5-1 shows the default left-to-right mapping of the three OPEN LOOK mouse buttons.
Table 5-1 OPEN LOOK Mouse Buttons
BUTTON
Description
SELECT
Specifies an object or manipulates objects and controls, drag
ADJUST
Extends or reduces the number of selected objects
MENU
Displays a menu associated with the pointer location or
specified object
The three Motif mouse button assignments, described in Table 5-2 , also start by default with the left mouse button.
Table 5-2 Motif Mouse Buttons
Button
Description
BSelect
Selects, activates, and sets the location cursor, drag
BTransfer
Moves and copies elements, drag and drop transfer. Can be customized to be the OPEN LOOK Adjust button.
BMenu
Displays menus
