Common Desktop Environment: Style Guide and Certification Checklist
ComboBox
y
n/a
n
Required
_
_
_
gw:
In a list that can be scrolled, such as a scrollable list box, do not allow the cursor to wrap.
Required
_
_
_
gx:
Provide vertical scroll bars when some of the data is not visible in the combo box.
Recommended
_
_
_
gy:
Provide horizontal scroll bars when elements are wider than the list box.
Recommended
_
_
_
gz:
Display the elements in an order that is meaningful to the user.
Recommended
_
_
_
ha:
Display an initial value from the list in the text-entry field. Display selected emphasis on the initial value so that typed text will replace the value.
Recommended
_
_
_
hb:
Make the combination box large enough to display a minimum of six list items at a time.
Recommended
_
_
_
hc:
When a user increases the size of the window in which the combo box is displayed, increase the number of items displayed in the combo box.
Recommended
_
_
_
hd:
When a user decreases the size of the window in which the combo box is displayed, decrease the number of items displayed in the combo box. As a minimum, reduce the combo box to the text-entry field and a list box with one entry displayed. If the window is sized so that two list items cannot be displayed, clip the combo box.
