Common Desktop Environment: Style Guide and Certification Checklist
CommandBox
y
n/a
n
Required
_
_
_
7-6:
If your application uses a command box, it is composed of a text component with a command-line prompt for text input and a list component for a command history area. The list uses either the single selection or browse selection model.
This specification ensures the consistent appearance and operation of a command box across applications.
Recommended
_
_
_
7-7:
When an element of a command box list is selected, its contents are placed in the text area.
This specification provides a convenient way of selecting a previously entered command.
Required
_
_
_
7-8:
The list navigation actions Up Arrow, Down Arrow, Control+Begin, and Control+End are available from the text component for moving the cursored element within the list and thus changing the contents of the text.
These actions provide a convenient way to choose a command from the list while focus remains in the text component.
Required
_
_
_
7-9:
The default action of the command box passes the command in the text area to the application for execution and adds the command to the end of the list.
Maintaining a history of commands provides a convenient means of entering often-used commands.
