A paned window, unlike most of the objects edited in the Revolving Property Editor, is a created object and is not available from an object palette. See "To Create a Paned Window " for instructions for creating a paned window.
Only properties unique to a paned window object are described here. See "Property Editor: Universal Properties" for descriptions of Object Type, Objects, Object Name, and Initial State.
Lists the panes that comprise the paned window.
Displays the W(idth) and H(eight) of the pane selected in the Panes list.
Specifies the Min(imum) and Max(imum) height (in pixels) of the selected pane. These values determine the limits for the panes when you move the sash between panes.
