Common Desktop Environment: Application Builder User's Guide
To Export a Module
Do the following to save a copy of a module in the current project. The current project is not affected when you export a module. A new module is created, which is not part of the current project; the original module remains as part of the project.
  1. From the File menu of the App Builder primary window choose Export Module and select one of the currently open modules from the submenu displayed.
    Or, in the Project Organizer select the module to be exported in the module array and choose Export from the Module menu.
    The Export File dialog box will be displayed, with the selected module name in the Enter file name field.
  2. Type a new file name in the Enter file name field
    Or, change to the folder where you want to save the module and type a file name in the Enter file name field.
    If you want to save a version of the module in the current folder, do not change folders. Simply give the module a different name.
  3. Click Export or press Return.
    A copy of the selected module has been created.
