Use Save As from the Module menu of the Project Organizer to rename a module. When you save the current project, the new module name will replace the old name in the project (.bip) file. The original module will still be in the project folder, but it will not be part of the project. To save a module without affecting the project, see "To Export a Module " .
Display the Project Organizer by choosing Project Organizer from the File menu of the App Builder primary window.
Select the module you want to rename.
Choose Save As from the Module menu.
The Save BIL File dialog box will be displayed, with the name of the selected module (with a .bil suffix) in the Enter file name field.
Type a file name in the Enter file name field.
Click Save or press Return.
The new module name will replace the old name in the project (.bip) file the next time you save the project.
