Common Desktop Environment: Desktop KornShell User's Guide
Second Area
The second area consists of a RowColumn widget, five ToggleButton gadgets, and another Separator widget.
Figure 4-6 Second Area of script_find Window
Graphic
A gadget is a widget that relies on its parent for many of its attributes, thus saving memory resources.
The RowColumn widget is created as a child of the Form widget, and positioned directly under the Separator widget created in the first area.
XtCreateManagedWidget RC
rc XmRowColumn $FORM \
          orientation:HORIZONTAL \
          numColumns:3 \
				 packing:PACK_COLUMN \
		$(DtkshUnder $SEP 10) \
		$(DtkshSpanWidth 10 10) \
		navigationType:EXCLUSIVE_TAB_GROUP
The five ToggleButton gadgets are created as children of the RowColumn using the convenience function DtkshAddButtons:
DtkshAddButtons -w $RC XmToggleButtonGadget \
     T1 "Cross Mount Points"           ""\
     T2 "Print Matching Filenames"     ""\
     T3 "Search Hidden Subdirectories" ""\
     T4 "Follow Symbolic Links"        ""\
     T5 "Descend Subdirectories First" ""
Another Separator is then created to separate the second and third areas. Note that this Separator widget ID is called SEP2.
XtCreateManagedWidget SEP2 sep XmSeparator $FORM \
     separatorType:SINGLE_DASHED_LINE \
     $(DtkshUnder $RC 10) \
		$(DtkshSpanWidth)
