To run the scripts, you need to know about two environment variables: KCMSROOT and KCMS_PROFILES.
KCMSROOT specifies the path to the top of the kcmstest directory.
KCMS_PROFILES specifies the path to the kcmstest/profiles directory. See Figure 2-1 .
Prior to running test scripts using the kcmstest command, you set these variables from the command line, for example
%setenv KCMSROOTpath
where path is the path to the kcmstest directory.
Alternately, if you run the automated script files, you set the variables at the time you run the scripts. See "Using Automated Script Files To Run Test Scripts" for details.
