Creating An Alternate Initialization File
You can create an alternate initialization file if, for example, you customized scripts for your CMM.
To create the file (see Example 2-1 ),
Use a text editor to save a copy of icc.ini under a new filename, for example alternate.ini.
Add (or remove) test script name(s) in the file list.
Change the value immediately following the [NumberOfTests] field to update the number of tests.
