For each script file executed, results are recorded in a log file. All the log files can be found in the kcmstest/log directory. The log file name is the name of the script file, with the .scr file extension replaced by the .log extension. If, for example, the test script name is IC_eval.scr, the log file name is IC_eval.log.
One exception to this naming scheme is if you enter all as the test script name. See "Starting the kcmstest Command" for details on this entry. In this case, the log file name is testall.log.
Two versions of a log file may exist at any given time: the current and the previous version. The previous version has its extension changed to .bak.
Example 2-3 is the log file output created from the test script shown in Example 2-2 .
Parsing a KcsLoadProfile
Command Profile Reference = scanner Profile File Name =
kcmsEKls3510.inp Profile Handling = By File Profile Load Hint
= LoadWhenNeeded; Profile Load Hint = UnLoadwhenNeeded;
Profile Operation Hint = Image; Load Hint = 2024000 Thu Jul
25 08:16:07 1996 Completed KcsLoadProfile command, status = 0 Thu
Jul 25 08:16:07 1996 Parsing a KcsLoadProfile Command Profile
Reference = printer Profile File Name = kcmsEKsunnws.out
Profile Handling = By File Profile Load Hint = LoadWhenNeeded;
Profile Load Hint = UnLoadwhenNeeded; Profile Operation Hint = Image;
Load Hint = 2024000 Thu Jul 25 08:16:07 1996 Completed
KcsLoadProfile command, status = 0 Thu Jul 25 08:16:07 1996
Parsing a KcsConnectProfiles Command Profile Reference = scan-print
Number of Profiles in Connect = 2 Profile Reference = scanner
Profile Reference = printer Operation Hint = 20001 Thu
Jul 25 08:16:07 1996 Completed KcsConnectProfiles command, status = 0
Thu Jul 25 08:16:08 1996 Parsing a KcsEvaluate Command Profile
Reference = scan-print Source Layout = RGBInterLeaved;
Destination Layout = RGBInterLeaved; Input Image Name =
macbeth_1550.tif Output Image Name = None Operation Hint =
20001 Thu Jul 25 08:16:08 1996 Completed KcsEvaluate command, status
= 0 364800.000000 pixels processed in 0.621338 seconds.
The processing rate = 587120.062500 pixels/second. Parsing a Free Profile
command Profile reference =scanner Completed KcsFreeProfile command,
status = 0 Parsing a Free Profile command Profile reference
=printer Completed KcsFreeProfile command, status = 0 Parsing a Free
Profile command Profile reference =scan-print Completed
