Follow the guidelines for running the test scripts described in Chapter 2, Running KCMS Test Scripts . If you just plan to run a few scripts, you can use the kcms_qatest command with command options. See "Using kcmstest To Run Test Scripts" in Chapter 2. Alternately, if you plan to run a large batch of scripts, the chapter suggests that you use the automated test scripts to do so. See "Using Automated Script Files To Run Test Scripts" in Chapter 2.
