So that the kcmstest command can find them, you must install all test scripts in the kcmstest/script directory. Install all profiles you want to use in the test suite in the kcmstest/profiles directory. (See "Required File Hierarchy " for a description of the KCMS test suite directory hierarchy.) Note that this profile installation is a separate installation from the one to set up your CMM (described in "Setting Up Your CMM" .)
You may choose to install links to the location of your profiles.
