IC_lana.scr
IC_lana.scr loads an arbitrarily large number of profiles and verifies that profiles can be connected and an image evaluated.
This script demonstrates that the KCMS framework can load and maintain several profiles in memory at the same time. The load hint specified in each of the load commands is AllNow. (See Table 3-11 for the LOAD: command LoadHint= keyword values and the corresponding load hints.) The type of profiles loaded varies (monitor, printer, scanner, color space). The script first loads all the profiles, after which it performs some simple operations such as CONNECT: and EVAL: to demonstrate that the framework can operate under these conditions. Then all the profiles are freed from memory with the FREE: command.
Each command is expected to return a successful status. Examine the test images output by the EVAL: command. Do not make color quality evaluations unless you have the appropriate devices to do so.
