KCMS Test Suite User's Guide
Evaluate Error
Script Name
IC_evalerr.scr
Concept
IC_evalerr.scr attempts to create test conditions that cause the EVAL: command to return various errors.
Description
This script demonstrates that the KCMS framework can perform a CONNECT: command under a variety of error conditions and return the appropriate error status. The script performs the CONNECT: command with the following error conditions:
Verification
Commands that are expected to fail will have the expected failure status provided as part of the EVAL: script command.
