IC_xdisplay.scr recognizes a display number when accessing a remote host.
This script demonstrates that the KCMS framework can recognize a display number when accessing a remote host. It requests a Solaris file profile from display 0.0 of a remote host that has a single display. It loads a local X Window System profile and sets an attribute to verify that the host is reset properly. Then it frees the profiles from memory.
The kcms_server(1) daemon must be running on the remote most. If it is not running, type kcms_server in a command shell as root on the remote host.
All the commands in this test are expected to complete successfully provided the kcms_server(1) daemon is running.
