IC_xprofile.scr tests ways of finding profiles.
IC_xprofile.scr sets the environment variable KCMS_PROFILES to a directory containing a profile called junk1.pro, which should be a copy of an existing profile copied to this directory prior to running the test. It essentially tests the ability of the library to use KCMS_PROFILES to find profiles.
All the commands in this test are expected to complete successfully.
