The following is an example of how to insert a configuration entry into the OWconfig file. Sample user responses are enclosed in brackets ([]).
ATTENTION:You must be root to update the OWconfig file. Are you inserting an OWconfig entry? y/n [y] You will be asked to supply a class, a name and a kcsLoadableModule to create an entry such as the following: class = "SUN_Xfrm" name = "acspdndp" kcsLoadable Module = "sunSUNWxfrmdndp.so.1" Please see the KCMS CMM Developer's Guide for information Enter the profile class name in the form of XXX_IO, XXX_Prof, XXX_Prfmt, XXX_Xfrm, or XXX_Stat. XXX is your unique cmm identifier, which must match the class name of your derived class. [KCS_Prof] Enter the name of your cmm - it must match the name in your derived class. [dndp] Enter the name of your dynamically loadable module. [kcsSUNWProfdndp.so.1] This is your OWconfig entry. OK? y/n class = KCS_Prof name = dndp kcsLoadableModule = kcsSunWProfdndp.so.1 [y] Do you have more entries to create? y/n [n]
The OWconfig_sample program above appends the entry to the OWconfig file.
Try inserting the entry shown in the above example:
Run the OWconfig_sample program. Be sure you are root.
Insert the user responses shown in Example 2-1 .
Check for the entry at the end of the OWconfig file.
The new configuration entry is appended to the end of the /usr/openwin/server/etc/OWconfig file. For local machine use only, the /etc/openwin/server/etc/OWconfig file is updated.
