The following is an example of how to remove a configuration entry from the OWconfig file. Sample user responses are enclosed in brackets ([]).
ATTENTION:You must be root to update the OWconfig file. Are you inserting an OWconfig entry? y/n [n] To remove an OWconfig entry: Enter the unique class name for your module for removal from the OWconfig file. The class name would be in the form XXX_IO, XXX_Prof, XXX_Pfrmt, or XXX_Stat [KCS_Prof] Enter the unique cmm name for your module for removal from the OWconfig file. [dndp] This is the OWconfig entry to remove. OK? y/n class = KCS_Prof name = dndp [y] Do you have more entries to remove? y/n [n]
The OWconfig_sample program removes the last entry in the OWconfig file.
Try removing the entry you inserted following Example 2-1 :
Run the OWconfig_sample program again. Be sure you are root.
Fill in the user responses shown in Example 2-2 .
Check the OWconfig file.
The entry should no longer appear at the end of the file.
