The KCMS profile name is a filename with the following naming convention:
<CMM ID><stock symbol><device>.<type> |
Table 2-5 describes the fields in the profile filename:
Table 2-5 Profile Filename Description|
Profile Filename Field |
Description |
CMM ID |
A mnemonic. Solaris-supplied profiles use kcms as the CMM ID. Choose your own mnemonic for profiles you create. |
stock symbol |
Short mnemonic used by the stock market for your company or a unique identifier. |
device |
Unique string identifying the device or color space. See Table A-1 for devices supported by Solaris. |
type |
ICC profile format standard filename suffixes. See Table 2-6 . |
