If RCS simulation is not available in the printer profile, the connect()() method connects the transformations by first connecting the into-RCS transformation of the scanner profile to the outof-RCS transformation of the printer profile, then to the into-RCS transformation of the printer profile, and then to the outof-RCS transformation in the monitor profile. Note that for the printer simulation transformation, the simulate-RCS is replaced with the combination outof-RCS and into-RCS transformations. This clips color to the simulated device.
If the simulated profile has neither the simulate-RCS nor the into-RCS and outof-RCS combination, connect()() returns a KCS_NOT_ENOUGH_DATA_4_OP error.
