Once a KcsIO object has been created, the profile can be loaded. Figure 3-4 illustrates creating a KcsProfile object.
In Figure 3-4, the first step to loading the profile is to create a new KcsProfile object with the createProfile()() static KcsProfile method. This method uses the CMM Id of the profile, which is located in a fixed place (bytes 4-7) in the profile header. (See "ICC Profile Header " for details.) The CMM Id determines the KcsProfile derivative to be created. If the CMM Id has no corresponding entry in the OWconfig file, the default KcsProfile class is created.
