Programming Utilities Guide
Retrieving Versions from Branch Deltas
Branch deltas usually are not included in the version retrieved by get. To retrieve a branch version (the version associated with a branch delta), you must specifically request it with the -r option. If you omit the sequence number, as in the next example, SCCS retrieves the highest delta in the branch:
$ sccs get -r 1.3.1 program.c
1.3.1.1
87
