At some point, perhaps when you've finished with the experiment, you might want to introduce the experimental features into production. But in the meantime, work may have progressed on the production version, in which case there may be incompatibilities between the branch version and the latest trunk version.
To help you sort this situation out, the -i option to sccs edit allows you to specify a list of deltas to include when you check out the file. If any of the changes that were included result in conflicts, edit issues a warning message. A conflict can arise if a line must be deleted to satisfy one delta, but inserted to satisfy another. While it is up to you to resolve each conflict, knowing where they are is a big help.
