Start prex on the kernel with the -k flag (make sure you are root). After prex successfully attaches to the kernel, it prompts you for commands.
# prex -k prex>
Only one prex session can be attached to the kernel at any given time.
The first step in taking a kernel trace is to allocate a kernel trace buffer. The trace buffer is circular, which means that newer data overwrites older data after the buffer fills up.
The default size for the buffer is 384 kilobytes, but you can override this when you allocate the buffer. When deciding on the buffer size, keep in mind that the buffer occupies both physical memory and kernel virtual memory, so it will impact the system you are tracing--the more RAM you have, the less the impact of measurement on your experiment, and the bigger the buffer you can allocate.
Use the buffer command in prex to allocate the buffer. For example, you could allocate a 512 kilobyte buffer as follows:
prex> buffer # do we have a buffer? No trace buffer allocated prex> buffer alloc 512k# allocate 512KB buffer Buffer of size 524288 bytes allocated prex>
The minimum buffer size is 128 kilobytes; prex allocates a buffer of this size if you request anything smaller.
Use the standard prex list command to list kernel probes and their attributes. For example, to list the name and keys attributes of the probe named pagein:
prex> list name=pagein keys name=pagein keys=vm pageio io
To list the name and keys attributes of all probes in the io group:
prex> list name keys probes io name=biodone keys=io blockio name=physio_start keys=io rawio name=pagein keys=vm pageio io name=pageout keys=vm pageio io name=physio_end keys=io rawio name=strategy keys=io blockio prex>
The next step is to trace and enable the probes you need. For example, to select all probes whose keys specify thread, vm, and io, and prepare them for tracing:
prex> trace thread vm io # attach trace function to probes prex> enable thread vm io # enable probes prex>
Unlike user-level probes, kernel probes are not automatically `traced' (in prex terminology) when prex attaches to the kernel. You must explicitly issue the trace and enable commands as shown above.
At this point the relevant probes are ready for tracing, but kernel tracing has not been globally enabled so no trace records are being written.
If you want to trace all system activity (for example, on a busy server), you can proceed to "Enabling and Disabling Tracing". This is the most common use of kernel tracing, and usually the most informative.
However, you also have the option of restricting trace data generation to selected processes; this can reduce the amount of data you need to collect and analyze.
prex uses two abstractions to allow you to do process filtering.
The process filter set is a list of process identifiers (PIDs) for those processes that you want enabled for tracing; no trace data will be written by (threads belonging to) processes that are not in the filter set. The default filter set is empty.
The process filter mode is a global flag that selects whether process filtering is enabled or disabled in the kernel. The default is that process filtering is disabled, which means that all processes (and threads) write trace records. When it is enabled, only (threads belonging to) the processes in the filter set write trace records.
Use the prex pfilter command to control process filtering.
prex> pfilter # are we filtering? Process filtering is off Process filter set is empty. prex> pfilter add 408 # add PID 408 to filter set prex> pfilter Process filtering is off Process filter set is {408} prex> pfilter on # enable process filter mode prex>
System threads (such as interrupt threads) are treated as belonging to process 0.
The final step in starting up tracing is to globally enable kernel tracing. When you do this, the probes you have enabled write records into the kernel trace buffer as they are encountered.
prex> ktrace # check tracing status Tracing is off prex> ktrace on # enable kernel tracing prex>
To trace the kernel behavior of your application (perhaps with user-level tracing enabled as well), start it running at this time. When your application finishes, or when you decide you have enough trace data to sample its behavior, globally disable kernel tracing.
prex> ktrace off # disable kernel tracing prex>
The trace buffer is still present in the kernel. Copy it out into a TNF file using tnfxtract. The procedure that you follow is explained in the subsection " Extracting Kernel Trace Data (tnfxtract)".
After you have copied the trace buffer into a TNF file, reset kernel tracing by disabling all probes and deallocating the buffer. This is important because it brings the performance of the kernel back to where it was before you started tracing.
Use the standard prex commands to disable and untrace all probes.
prex> disable $all # disable all probes prex> untrace $all # untrace all probes prex>
Finally, use the prex buffer command to deallocate the trace buffer.
Do not deallocate the trace buffer until you have copied it out into a trace file. Otherwise, you will lose the trace data you collected for your experiment.
prex> buffer dealloc # deallocate buffer buffer deallocated prex>
You can now quit prex and examine the trace data that you have collected.
prex> quit #
