Use the tnfxtract utility to make a copy (or snapshot) of the active kernel trace buffer into an external TNF trace file. You typically run the utility after tracing has been disabled, although you can also run it concurrently with tracing. The utility ensures that it reads and writes only consistent TNF data.
Specify a file name that tnfxtract can use to hold the extracted kernel trace data. This file will be overwritten and truncated to the size of the kernel trace buffer. For example, to extract it into a temporary file named ktrace.tnf:
# tnfxtract /tmp/ktrace.tnf # ls -l /tmp/ktrace.tnf -rw------- 1 root other 524288 Aug 15 16:00 /tmp/ktrace.tnf #
You might find it convenient to change the permissions on the trace file so that it is world-readable. This makes it easier for you to run analysis tools over the file when you are not superuser.
You can also use tnfxtract on a kernel crash dump; see tnfxtract(1) for details.
