This program, cookie.c, asks for a cookie. The response must be entered in uppercase, or it is incorrect. You can also find the prime factor of a number. In the process of doing these two things, you can see how the trace function works.
To compile this program and get an executable called cookie(), use
$ cc -o cookie cookie.c
Five probe points are defined (and highlighted) in this program. They are named start (line 17), inloop (line 33), factor_start (line 60), found_a_factor (line 65), and factor_end (line 72). More information about these probe points is gathered and explained in "A Sample prex Session".
#include <sys/types.h> #include <stdio.h> #include <string.h> #include <tnf/probe.h> #define MAX_RESPONSE_SIZE 256 static void find_factor(int n); int main(int argc, char **argv) { boolean_t shouldexit = B_FALSE; int sum = 0, max_loop = 5; int i; TNF_PROBE_0(start, "cookie main", "sunw%debug starting main"); while (!shouldexit) { char response[MAX_RESPONSE_SIZE]; int factor_input; (void) printf("give me a COOKIE! "); (void) scanf("%s", response); if (!strcmp(response, "COOKIE")) { (void) printf("thanks!\n"); shouldexit = B_TRUE; } else if (!strcmp(response, "loop")) { for (i = 0; i < max_loop; i++) { TNF_PROBE_2(inloop, "cookie main loop","sunw%debug in the loop", tnf_long, loop_count, i, tnf_long, total_iterations, sum); sum++; } max_loop += 2 ; } else if (!strcmp(response, "factor")) { (void) printf("number you want factored? "); (void) scanf("%d", &factor_input); find_factor(factor_input); } else { (void) printf("not a %s, ", response); } } return 0; } /* end main */ static void find_factor(int n) { int i; (void) printf("\tfactors of %d = ", n); TNF_PROBE_1(factor_start, "factor", "", tnf_long, input_number, n); for (i=2; i <= n; i++) { while (n % i == 0) { TNF_PROBE_2(found_a_factor, "cookie find_factor", "", tnf_long, searching_for, n, tnf_long, factor, i); (void) printf("%d ", i); n /= i; } } TNF_PROBE_0(factor_end, "factor", ""); (void) printf("\n"); }
