This sample of a prex session is designed to show the different capabilities of prex. The data collected when cookie is run is shown in "Reading the tnfdump File".
% prex cookie /* prex is loading the executable cookie. */ Target process stopped Type "continue" to resume the target, "help" for help ... prex> list sets $all 'keys'=/.*/ /* One set is defined--$all (which is all the probes). */ prex> list fcns &debug tnf_probe_debug /* The debug function is the only one available. */ prex> list probes $all name=inloop enable=off trace=on file=cookie.c line=35 funcs=<no value> name=factor_end enable=off trace=on file=cookie.c line=72 funcs=<no value> name=factor_start enable=off trace=on file=cookie.c line=61 funcs=<no value> name=found_a_factor enable=off trace=on file=cookie.c line=67 funcs=<no value> name=start enable=off trace=on file=cookie.c line=17 funcs=<no value> prex>/* The line number shows the end of each of the five probes. */ prex> create $factor /factor/ /* Create a new set that matches any probe whose "keys" */ prex> /* attribute contains the string "factor". */ prex> list sets $all 'keys'=/.*/ $factor 'keys'=/factor/ /* A new set named "factor" is created and now shows up in */ prex> /* the list of sets. */ prex> list probes $factor /* This line tells you which probes matched the set $factor.*/ name=factor_end enable=off trace=on file=cookie.c line=72 funcs=<no value> name=factor_start enable=off trace=on file=cookie.c line=61 funcs=<no value> name=found_a_factor enable=off trace=on file=cookie.c line=67 funcs=<no value> prex> list probes $all /* Check to see if any probes are enabled. */ name=inloop enable=off trace=on file=cookie.c line=35 funcs=<no value> name=factor_end enable=off trace=on file=cookie.c line=72 funcs=<no value> name=factor_start enable=off trace=on file=cookie.c line=61 funcs=<no value> name=found_a_factor enable=off trace=on file=cookie.c line=67 funcs=<no value> name=start enable=off trace=on file=cookie.c line=17 funcs=<no value> prex> /* None are enabled, but all have trace on. */ prex> enable $all /* Enable all the probes.*/ prex> list probes $all /* Check again to see if any probes are enabled. */ name=inloop enable=on trace=on file=cookie.c line=35 funcs=<no value> name=factor_end enable=on trace=on file=cookie.c line=72 funcs=<no value> name=factor_start enable=on trace=on file=cookie.c line=61 funcs=<no value> name=found_a_factor enable=on trace=on file=cookie.c line=67 funcs=<no value> name=start enable=on trace=on file=cookie.c line=17 funcs=<no value prex> list values name /* Find out what the probe names are. */ name = factor_end factor_start found_a_factor inloop start prex> list values /.*/ /* List all predefined attributes with their values. */ enable = /* Only unique attributes are listed.*/ on file = cookie.c funcs = keys = cookie factor find_factor loop main line = 17 35 61 67 72 name = factor_end factor_start found_a_factor inloop start object = cookie slots = factor input_number loop_count searching_for total_iterations sunw%debug = /* The user-defined macro, sunw%debug, is also listed. */ in /* This macro is defined in line 17 of cookie.c. */ loop main starting the trace = on prex> list values object object = cookie prex> connect &debug name=inloop prex> list /.*/ probes $all /* List all the information about all the probes */ enable=on trace=on object=cookie funcs=<no value> name=inloop slots=loop_count total_iterations keys=cookie main loop file=cookie.c line=35 sunw%debug=in the loop enable=on trace=on object=cookie funcs=<no value> name=factor_end slots=<no value> keys=factor file=cookie.c line=72 enable=on trace=on object=cookie funcs=<no value> name=factor_start slots=input_number keys=factor file=cookie.c line=61 enable=on trace=on object=cookie funcs=<no value> name=found_a_factor slots=searching_for factor keys=cookie find_factor file=cookie.c line=67 enable=on trace=on object=cookie funcs=<no value> name=start slots=<no value> keys=cookie main file=cookie.c line=17 sunw%debug=starting main prex> continue give me a COOKIE! loop /* An example of loop counts*/ probe inloop; sunw%debug "in the loop"; loop_count=0; total_iterations=0; probe inloop; sunw%debug "in the loop"; loop_count=1; total_iterations=1; probe inloop; sunw%debug "in the loop"; loop_count=2; total_iterations=2; probe inloop; sunw%debug "in the loop"; loop_count=3; total_iterations=3; probe inloop; sunw%debug "in the loop"; loop_count=4; total_iterations=4; give me a COOKIE! factor number you want factored? 25 factors of 25 = 5 5 give me a COOKIE! factor number you want factored? 43645729 factors of 43645729 = 43645729 give me a COOKIE! ^C Target process stopped Type "continue" to resume the target, "help" for help... prex> continue give me a COOKIE! biscuit not a biscuit, give me a COOKIE! cookie not a cookie, give me a COOKIE! COOKIE thanks! prex: target process finished
