During phase 1, fsck(1M) determined that the specified inode pointed to a number of bad or duplicate blocks, so the block count should be corrected to the actual number shown.
Generally you can answer yes to this question without harming the filesystem.
For more information on bad blocks, see the section on checking filesystem integrity in the System Administration Guide, Volume I.
