This is a server which has several clients. It seems when the backup kicks off many the savesets are failing with the message listed below.
godzilla index failed:full:index * godzilla:index 2 retries attempted * godzilla:index sh: save: not found |
Edit the /etc/init.d/networker file and change the nsrexecd startup line to include a -p option to specify the command search path :
(/usr/sbin/nsr/nsrexecd -s masters -p /usr/sbin/nsr ) > /dev/console |
