This message can appear when someone runs a command from the shell or uses a third-party application. The sar(1) command does not indicate that the system-wide open file limit has been exceeded.
The probable cause of this message is that the shell limit has been exceeded. The default open file limit is 64, but can be raised to 256.
See the message "Too many open files" for a solution.
