Solaris Common Messages and Troubleshooting Guide
Cause
While trying to mount a filesystem, the mount(1M) command received a "Device busy" (EBUSY) error code. There are several possible reasons: this /dev/dsk filesystem is already mounted on a different directory, the busy path name is the working directory of an active process, or the system has exceeded its maximum number of mount points (unlikely).
