Run /etc/mount to see if the filesystem is already mounted. If not, check to see if any shells are active in the busy directory (did the user cd(1) into the directory?), or if any processes in the ps(1) listing are active in that directory. If the reason for the error message isn't obvious, try using a different directory for the mount point.
